waynorth
- Joined
- Aug 28, 2018
- Messages
- 674
- Reactions
- 728
Thanks. Will be interesting to see if they have improved it.
see above
Sounds encouraging. I hope the manufacturing tolerances will also be tightened as it was not uncommon that the M3 would suffer from lens decentering and other lens related issues causing blurry areas in the frame etc. Getting a good one was more of a good luck than a norm.Looks like my expectation is just about right. DJI finally addressed one of the biggest complaint for Mavic 3.
Is 1/1.3 an inch? I get confused with this stuff.[4/24/23: Added leaked official specs for Mavic 3 Pro]
I created a couple of images, to compare the camera module between Mavic 3 and Mavic 3 Pro. The size difference is quite significant.
The take-off weight has increased from 895g to 958g. Cine version is even heavier.
As result, the official flight time is reduced from 46 to 43 minutes. The realistic flight time is more likely around 28-30 minutes.
If I have to take a guess, this new triple camera set up is a sweet spot DJI found, after testing prototypes with multiple lens and sensor configurations. Ideally I want a 7X zoom camera with one inch sensor, but it may not be doable without compromising too much gimbal performance and flight time.
It's smaller.Is 1/1.3 an inch? I get confused with this stuff.
The naming of sensor sizes follows an odd system that is hard to make sense of.Is 1/1.3 an inch? I get confused with this stuff.
No it is something like .80 .somewhat less than an inch.Is 1/1.3 an inch? I get confused with this stuff.
If you didn't have me on ignore, you'd have seen that I posted the actual size (which is quite a bit less than 0.8 inches) and an explanation of why the sensor sizes have no relation to their actual size.No it is something like .80 .somewhat less than an inch.
Looks like the camera is heavier than the Mavic 3 Classic version which will imply the a European C1 approval will not be met. The total weight must not exceed 900 grams to comply.
See updated post with leaked official specs. The take-off weight for Mavic 3 Pro is increased from 895g to 958g. Cine version is even heavier.
I've not seen any of that where I've been in Australia, and certainly nothing based on the weight of drones.That seems to be the case in a lot of Australian towns, they will often have information about drone permit fees, which are not trivial, because they figure you're making money from flying in their towns.
For instance look up Melbourne, the Council website.I've not seen any of that where I've been in Australia, and certainly nothing based on the weight of drones.
Everywhere seems to have a pretty laid back attitude towards drone use.
You are talking about a couple of urban areas in large cities.So wHats a few thousand for the right to film in one of the most photogenic cities in the world?
It's only a mile from the Melbourne CBD and is just out of frame to the right of this shot.Hmm, the area I'm talking about doesn't seem to be dense like Manhattan. It's more towards the outlying suburbs and I certainly wouldn't fly between the skyscrapers lining along the river.
This text does not seem like an official DJI statement. It is not written in the typical DJI-blurb, and they would never call the telephoto lens an optical zoom. They have never done that before.The improvement is real. It is mentioned in the leaked official press release, which is supposed to go live tomorrow. The only question is, to what degree is the optical improvement affects the final image quality. We shall find out pretty soon.
By the way, I think the "29X hybrid zoom" there must be a typo. Should be 28X instead.
It's definitely odd.This text does not seem like an official DJI statement. It is not written in the typical DJI-blurb, and they would never call the telephoto lens an optical zoom. They have never done that before.
Looks like DJI's marketing department doesn't know what zoom means.This text does not seem like an official DJI statement. It is not written in the typical DJI-blurb, and they would never call the telephoto lens an optical zoom. They have never done that before.
Yea they definitely don't. It's a prime telephoto lens on top.Looks like DJI's marketing department doesn't know what zoom means.
Now it's confirmed .. The Mavic 3 has optical zoom (according to DJI's marketing department who wouldn't even know which end of a camera to look in).
Can't confirm, but I've read the 4/3 camera has a newer Sony IMX472 stacked and backlit sensor. May help a little in low light, but I'll be waiting on comparisons.K, guess now that it's out. Seems like the only thing they did to it was introduced two telephoto options and add dlog-m (in addition to the existing dlog).
And then reduced the flight time and increased the weight.
So I guess if you need the tele it's good otherwise not much different than the mavic 3.
