Mavic Air 2 extended battery possibility
In all honesty, I get more than enough flight time out of each battery and don't see the benefit into risking opening up a battery or altering the flight characteristics of the drone. I have four batteries total and that's an afternoon of flying. Typically I use one to two batteries at each location I go it. I keep it legal and fly within VLOS so no need for distance. Landing and replacing a battery isn't a big deal or hard to do and it doesn't bug me in the slightest to do that after 25 minutes of flight time. I'm due for a little break for a minute by then anyways.
Reactions: MA2 317
When the Air 2 arrived people applauded the longer flight time. With the Fly More pack there were two extra batteries and a charging bank. That’s 80+ minutes in the air. Why risk a great drone and the safety of people on the ground by fiddling around with the power source that the DJI technical experts have specifically designed for the Air 2. It makes no wise sense to me.
ingenuity is what drives better products. DJI might be satisfied with their profit numbers increasing because they can build X drone with y (cheap) parts. If the current market is satisfied with a drone that can fly 34 minutes, that is what they are going to build.
If some kid can increase a DJI drone flight time by tinkering in his garage and people realize there is the possibility for better products, that can force DJI with the numerous engineers and facilities to the drawing board to be more innovative.
I bought the connector, LED light, and a new 4S battery from hobby king to test and play with the Mavic Air 2.
I know it's overkill, unnecessary, and all that, but for me is fun, interesting and I like to see the limits even if goes wrong. Is the nature of some people. Have fun !!
Reactions: nencmeister
Please report back here with your results and maybe even some links of what you exactly bought.
Reactions: dawgpilot
That is what I bought. for the Mavic 2 Pro
For DJI Mavic 2 Pro/Zoom Power Supplier Adapter+Adhesive Tape Battery Supplier | eBay
For the Mavic Air 2
and
For the Mavic Air 2
and
Thank you for the link. Looking forward to hearing how it flys and for how long.
Reactions: GadgetGuy
4S for MA2 ? no-wayyyy ....... MA2 supports 3S HV but not 4S !!! and the results of your tries?
You are correct. the 4S was for the M2P. The MA2 is 3S sorry for the mistake.
Just bought these, since it's not very clear what the results are, I'm happy to test :)
Also just got an Alientech Duo II, can't wait hehe.
Also for the guys against modding, modding/hacking is normal for anything. We put superchargers in our cars, upgrade sound systems, lift weights and eat more protein. It's human nature to push the limits.. and then some :)
Reactions: zeusfl
Adding a battery won’t necessarily increase the flight time. The drone’s motors spend most of their energy lifting the drone and it’t battery. If you double the weight of the batteries being carried, you will only get a slight increase in flight time, as the doubled battery weight takes almost double the energy.
DJI, as part of the drone design, have optimized the battery-aircraft combination to maximize flight time performance. Amateur tinkering is unlikely to beat their engineering unless you can invent a better battery with a better power to weight ratio.
MA2 weighs 570g, doubling the battery would increase it to 760g. That's +33% weight (and energy to lift), far from "almost double" as you wrote it.
More specifically, the MA2 draws around 10 amps hovering with double battery and 7 amps with stock, more or less matching the calculation above.
You don't need to mistify DJI engineers: simply, they needed to make a popular drone that performs in many conditions even for amateur-ish pilots, and provide warranty and to some extent liability to their products. Doubling the battery admittedly reduces maneuverability, top speed and wind resistance, and maybe makes the drone sightly less stable due to the higher center of mass. For many hobbyists, this is acceptable in exchange for 40-45 minute (or 20km+) flights.
I'm looking at this Startrc power out connector for the mavic air 2 and am wondering if this will actually work...
They're on ebay for even less. Problem is I can't find any reviews.
What if I buy that and then grab a battery like this one:
Anyone tried this yet? The voltage is the same and it's about 60% of the capacity of our normal mavic air 2 battery...so I'm thinking if this works we'd get around 45 minutes of flight time...or maybe even better, we get our 34 minutes of flight time, then land with around 30-35% battery left in the DJI battery, extending its lifetime.
The weight of the battery is 350 grams and people are saying online this baby can carry way more than that.
Yell at me if this is a bad idea.
Don't do it
RYNOGOD
