Mavic Air 2 operation
LLeitzel
PA
Right and left, lateral movement is gone. Stick movement does not produce drone movement. Worked well in the past. Help?
Check the settings in the app.
There is a setting about the obstacle avoidance that has options on what the aircraft does.
One of those options has a slider switch to cancel the left, right movement so you can fly a straight line.
Perhaps that got switched?
Good luck. ?
MA2 317 is correct. I've seen a toggle switch that turns lateral movement of the drone on and off. It has this option, because the Air series of drones do not have side sensors. Turning off lateral movement prevent the drone from flying sideways to avoid hitting objects to it's sides. Do you fix your problem yet?
Reactions: MA2 317
jigjjihhwohekjgh2857
