Mavic Air Fan Connector Damaged - Advice needed
Pajamapants
Chicago
Good Day,
I had my first crash.
After the crash the gimbal was a little loose so I took apart the mavic air to fix the issue. I fixed the gimbal arm break with some resin and super clue layers and it seemed to work great on my next flight.
I wanted to reinforce the bond so I took apart the mavic air one more time and I accidentally snapped the plastic small section that braces the fan connection to the motherboard.
I am not sure if I can just solder this back on or what to do at this point to reestablish the connection.
Do you mean this plug point, I suspect it would be very hard to resolder it back as it's 4 tiny contact points.
A main board replacement would be the best option
Reactions: pelagic_one
Hi
What is that 4 pin connector called that connects the fan to the motherboard (the one that is soldered to the motherboard as i need to purchase it
thanks
Andrefu
