Mavic controller left antenna is loose
Spin
Any way to tighten up the antenna on the Mavic controller?
Gearbest will sell just the Mavic for a grand but then again its only 90 bucks more for the remote.
Same issue here. Was fine for a week when I first got the drone. Now the left antenna flops around and the right one is nice and stiff. Seems like others are having the same problem.
the antenna is friction controlled,i think as i watched a guy remove both for antenna up grade. I took a Popsicle stick aligned it with both antennas marked the sides of the stick to coincide with ant width drilled two holes for each ant and secured each with small zip ties at the base of each antenna no more wiggle and it can be removed with ease. sort of like the stick guard that are available for mavic pro.
RYNOGOD
