- Joined
- Oct 12, 2016
- Messages
- 28,432
- Reactions
- 31,326
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
That's the part you need. There is no way to just replace that tab.I found the replacement of the entire plate.
- Keeping the battery fully charged for long periods of time
Yes.Is it ok to have a fully charged battery sit for 10 days and have it auto discharge?
with any lipo battery there is an 80/20 rule... don't charge it more than 80% (or close) and don't discharge is below 20% (or close) to ensure full health of the battery.Quick question.... Don't ever store your batteries fully charged ?
VPS = the downwards looking caneras and ultrasonic sensors that sense height above ground and horizontal movement at low altitudes. They were visibly disturbed and always thinking you were already on the ground preventing futher descent becaue you likely had the "landing protection" setting on. Most likely due to that landing gear that several have previously warned not to use, if you put one (unnecesary in most cases) you want one that extends out the back and leaves all the sensors perfectly clear.
The swollen battery is due to the severe overdistcharge that resulted from the aircraft waiting for an opportunity to land that never came, and is now good for the trash.
People really use too many poorly designed acessories on this poor Mavic.
I have been seriously thinking about disabling the "Landing protection." I honestly don't see any point of it. I have the landing extenders, which have worked well so far. I just don't like the idea that the props are a mere 1/2" off the ground, and that landing anywhere than a perfectly flat, level surface is a deal breaker. With the extenders, I'm given some latitude regarding landing surface. The Landing Protection hasn't screwed me yet, but with this new information, I just may turn that thing off. Unless I'm flying indoors, I may turn off VPS altogether.
i think that would cause it to rapidly raise in altitudemy guess for not responding to landing command: rear extender put wrong blocking the sonar.
I have the same "landing gear" and have never had an issue with the sensors. The U-shape wraps around the back of the MP not under it.VPS = the downwards looking caneras and ultrasonic sensors that sense height above ground and horizontal movement at low altitudes. They were visibly disturbed and always thinking you were already on the ground preventing futher descent becaue you likely had the "landing protection" setting on. Most likely due to that landing gear that several have previously warned not to use, if you put one (unnecesary in most cases) you want one that extends out the back and leaves all the sensors perfectly clear.
If you ever see that happening mid-flight in the future, you should disable the Landing Protection setting. That will prevent the auto ascent/descent when the downward sensors incorrectly detect the ground is near. You'll find that setting in the following section of DJI GO:
Yes I can confirm that as I did a manual vertical descent in sport mode at 10m/s and thought the auto landing sensors would kick in but they don't! Rather a hard landing and broke the camera ribbon in the process. So to quickly disable the auto sensors just switch to sport mode using the side switch.Would putting it into Sport Mode produce the same result? I read all this stuff so I'm prepared.
Yes, but remember that sport mode must be activated on the menu, by default it is disabled.Yes I can confirm that as I did a manual vertical descent in sport mode at 10m/s and thought the auto landing sensors would kick in but they don't! Rather a hard landing and broke the camera ribbon in the process. So to quickly disable the auto sensors just switch to sport mode using the side switch.
