- Joined
- Oct 12, 2016
- Messages
- 28,388
- Reactions
- 31,261
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
The solution is to not use DJI GO 3.1.2 on an Android device. Nobody should be using that version of DJI GO.Is the DJI GO 4 app the solution?
Still strange that a new homepoint was installed at a place I never was and never saw on my phone.It does, but the home point will switch to your mobile device's current location if you choose to return to the current location when initiating RTH.
Installed GO 4, thanks for the advice.The solution is to not use DJI GO 3.1.2 on an Android device. Nobody should be using that version of DJI GO.
Well, for me still not resolved. Is the DJI GO 4 app the solution? What can I read/learn from the Healthy Drones flight data? Will it happen again and what to do.
You see, I am a novice, just got my mavic last week.
I can't really help the OP here, but I'd like to know why AyeYo is implying that RTH should only be used in an emergency situation. It's a function programmed into the unit, and it should be work whether you are in an emergency situation or not. Once I find a place big enough to test out all the functions of my mavic safely, I plan to test RTH. Will I be in an emergency situation? Hopefully not. Do I still expect it to work properly? Of course.
See my comments above. This is a well known bug in DJI GO 3.1.2 for Android.The DJI Go 4 app is designed for the Mavic. The other is not. You shouldn't have these issues in the future.
Yes, sir. Bugs in software often cause strange things to occur.
That's correct. This bug only exists in the Android version of DJI GO 3.1.2.The RTH bug with DJIGO 3.1.2 app is only with android and apple phones are not affected?
If one initiates RTH and is prompted to return to the original home point or the current location, this bug will cause the home point to be reset to a far away location if current location is selected.Clarity please? If one simply hits RTH, then the home point should be the point that the Mavic started at, got good GPS?
When RTH is initiated, the Mavic should always go to the last marked home point.
It depends. If you set the home point to the mobile device's current location, it'll use the mobile device's GPS receiver to find the current location. That would of course fail if the mobile device does not have a GPS receiver.
Where do you find the app version on the flight log?You can find the DJI GO version in the "General Settings" --> "About" section of DJI GO. There is no need to check though. Your flight log shows you were using version 3.1.2.
That is exactly what happened to me. A new home point out of the Blue. I hope with the new app (4) it's over.If one initiates RTH and is prompted to return to the original home point or the current location, this bug will cause the home point to be reset to a far away location if current location is selected.
Amen. Sometimes I just scroll through responses until see a response from msinger. Saves a lot of time.LOL...it's funny how many times you've said this, and no one's paying attention to the simple solution LOL!
Guys...if there's one lesson you should learn from this forum it's this: when @msinger gives you advice or suggests something...listen to him!
