Mavic Pro 2
kiteboarder
I am getting choppy video where it speeds up periodically when using active track when I play it back on my iPhone on the DJI go 4 app.
Try playing it back on a Mac, iMac or PC and see if you still have the choppy playback. Use VLC player.
I get terribly choppy 4K playback with 4K 60FPS from P4 Pro, even in Final Cut, (export is fine), but I still will preview with VLC player as it always seems to work.
The video on the iPhone should be from DJIGO4 cache and I don't believe it will have full rez or good playback if in 4K.
Paul C
There will almost always be some noticeable latency between devices, or over the air.
Copy your media to your pc and view it directly. VLC is a great recommendation, as mentioned above.
Eng.Sabri
