Mavic pro distance issue - help needed pls MP seems to go only to a distance of 40 mts or so, not on beginners mode and flight distance is on 5000 mtr
Pierre camilleri
Mavic pro distance issue - help needs pls MP seems to go only to a distance of 40 mts or so, not on beginners mode and flight distance is set on 5000 mtr - any suggestion of what might be wrong pls ?
Do you have sufficient GPS satellite locks? What colour does the rear LED flash?
A mavic pro is not a new drone so, if this is not new to you have you previously flown this, from the same place, with out any distance limit?
If so have you changed anything since then e.g. up dated the app or the firmware or any thing else, phone?
Posting your DAT and txt flight logs might also be helpful, see DJI Flight Log Viewer | Phantom Help for instructions.
ad60
