Mavic Pro II specs.
Status
Not open for further replies.
FYI, the source of those updates is OsitaLV on Twitter. Follow him there to get the latest updates.
I think the size of the Mavic Pro-II will be almost entirely dominated by the size of its new camera.
If it really is getting that Sony 1inch-type Exmor R model sensor, than the size of the aircraft will need to hold a much larger camera body and gimbal.
Look at the Phantom 4 Pro, its large gimbal is closer to the center of gravity under the frame. Its got overly large landing gear to hold that camera just barely off the ground. The Mavic Pro-II could likely have a front load weighted design that will be alward for the rotars to balance so the battery might need to be closer to the back to counter balance and center the weight.
Have you guys seen the P4P's one inch camera and gimbal? Can you imagine throwing "that" to the front of a "small" or current sized Mavic Pro?
THIS NEW DESIGN IS GOING TO BE TRICKY!!
Im skeptical that OsitaLV's Mavic Pro-II drawings are legit. Im thinking that he is way off....but who knows?
CT
Reactions: Neckcrank
Status
mupps64
