Mavic Pro Platinum Help (Is this antenna still usable?) Pictures of both sides of antenna.
if the metallic film that the wire is soldered to is still in tact then you could very carefully super glue the other side to affect a repair it is the length of the antenna that is important
Thank you for the info! The soldering is still intact!
i was referring to the actual bit where it has snapped that needs to be glued back together
Wouldn’t advise cutting costs on primary system components.
Secondary components I have no problem with
deepdark
