If it's too hard to get the flight data, can you describe your launch site?I'm working on it, but my Mac is also dying so I can't hook up to itunes
Launched from a bridge?Launched from a trail in the woods, Over a railway bridge, where the forest meets the waterfront in bates park
Crashed at the yellow highway bridge.
Only two problems with that.Malfunction is completely their fault. Full refund it shall be. Have you tried?
I agree, I haven't read anything to this point that shows a definitive malfunction of any kind. That's a big leap on evidence up to now and one I would bet DJI won't agree with.Only two problems with that.
How do you know the problem was a DJI issue?
If he can't return the drone to DJI for their investigation, how will they know what the cause of the incident was?
No the trail is up on the hillside, the bridge is at the shoreline. I was panning away from the bridge before the drone took offLaunched from a bridge?
A bridge with a lot of steel in it?
What I said back in post #12 still goesNo the trail is up on the hillside, the bridge is at the shoreline. I was panning away from the bridge before the drone took off
What possible evidence do you have to make this bold statement??Malfunction is completely their fault. Full refund it shall be. Have you tried?
Reviewing the flight record and video feed, you can see i'm not touching the joysticks after initial take off... for 10 seconds until the very last second in an attempt to avoid the crash.
yes, you are right. the double tracks is just where you got the GPS fix, it's not the takeoff point, my bad.I certainly didn't launch from the double railway tracks. The tracks with the railcars are down below at the shoreline running east-west
As long as you did not have GPS lock, the compass issue does not matter because the drone is not using it.Even though the compass would be off, I can understand that having an affect on the drone turning the wrong way maybe, but I was operating it successfully to start and then it just took off without any controller input...
Also FYI my joysticks aren't default, left stick is elevation and sideways banking.
Right stick is forward/back and yaw (turn)
First and last image included
Are compass issues common? Because I wasn't prompted to calibrate on this flight, but my previous launch --in a forest with no interference-- it wouldn't calibrate
