Maximum Write Speed
Bunraku
Hi
Does anyone know what the maximum write speed is that a Mavic Air 2s can write to a micro sd capable of that maximum write speed?
Thanks
Am not aware of a way to measure the actual write speed in the drone, just to see the effects when you get a card that's too slow.
Even hooking up to the drone's USB and measuring the write speed over that would be affected by other bottlenecks in the system so wouldn't give useful data.
Hi
Thanks
While the DJI Air 2S only records 150mbps (18.75MB/s), it needs memory card write speeds of at least 18.75MB/s to operate.
According to this [source]
The DJI Air 2s drone is packed with a ton of features and some really competitive video recording specs such as 5.4k 150Mbps H.265 recording with various Log options.
To take advantage of the best video specs and features this drone has to offer, you will need to choose the right memory card. This means a minimum of a UHS-I with a U3 rating, but also a card no larger than 256GB which is the maximum capacity for the Air 2s.
Reactions: danwnz
engmarceloacs
