Mini 2 Motor Malfunction
Later2u
Brentwood, California
Crashed my DJI Mini 2. Broke top cover, mid case and front right propellers. Replaced all.
After repairing everything, this is the issue I'm having. Right motor not fully spinning up.
At this point, I'm assuming the front right motor is somehow damaged.
It starts up, but does not spin up like the other motors?
I have no error codes, the Mini and controller operate with no issues, except for the front right motor.
Motor spins freely, like the others.
I will be replacing this arm and motor to repair and verify.
Any insight to if this is the actual issue would be helpful.
Thank You,
Here's a short video showing the issue.
Thanks for the reply guys, or gals.
I replied to that post from Sean and I will duplicate my reply here to close out this thread.
Thanks for the reply Sean,
The propellers are in the proper configuration. I did review some pictures I took as I went through the process and lo and behold, what did I find.
I indeed had switched two wires to my chagrin.
Thanks for the prompting of verifying these items.
I should be back in the air soon.
Thanks again.
Reactions: Phantomrain.org
Sam the Slam
