Mini 3 4 Dual Lighting Mount
Here is what I have Black, Grey White Black,Grey Matte (not as strong) and these two
You can also lookup Hatchbox or eSUN PLA PLA + on Amazon 1.75mm
The grey matte will be more than fine IronSky, I'm not that fussed that you would have to buy a whole new spool for it.
I just applied some nice fluro yellow 3M decals to my m4p but they only add about 0.1mm to the casing so I can just sand back the bracket if it needs it.
Do you have a web form or oboarding payment flow link with inclusive shipping calculator for this to select the matte grey or just the eBay listings as shown ?
takk
You wont have to sand back anything with that thickness.
This is link the one has mounts for various lights like Imalent and RovyVon the other include to lower cost lights. I ran tests on various lights and post on first page of this. You can swap mounts per your lights
alright that's fine, will the spacing for the GoPro light's (those are the cradle clips oh each side yes ?) bend or break slightly to fit a torch tube such as this one ?
thank you for the ongoing thread guidance
That light has a stepped tube. If you can remove one end can you get to the center area and measure it. Other wise you would need a custom clamp. The light is available from Amazon I can always get one and measure. It notes 20mm .787" I would presume the large end. Do you already have this light. If not I would look at the RovyVon it is the smalest and lightest for this application.
No i don't have any of these light's as yet, it just looked the coolest while keyword searching for something suitable.
Just received the RovyVon A3 Pro lower cost version 27USD vs 36USD
1-Same size fit in my standard mounts
2-The reflector has a texture on it
3-They both measure the same at .5m 5500-6500 lumens 200 lumen basline
4- Both weight the same 19g
Cool. Maybe you can make a mount to stick a couple of these on the Avata 2 like headlights.
RovyVon actually makes a dual version of this light. Currently printing some test mounts.
danyjames_
