mini 4 pro r/c drop connection at 1 kl?
John Gowland
Perth
Why does my Mini 4 Pro r/c start to drop connection at 1kl?
I don't want to start a debate about the wrongs and rights. Just some help with a solution would be appreciated. Ta.
Other interference is usually the largest problem
Reactions: John Gowland
Interference with the signal.
That's as much as can be said given the constraints you've placed on the discussion. Any more detailed theory will, with absolute certainty, result in debate.
I’ve tried it in cities to non-urban areas, beaches, sea, and lakes. It seems to make no difference. I have looked at range extensions and wonder if anyone has tried them? My line bar is under the 4k and on the 1k so I am assuming its the long range one. So have people had no such problem?
flymehome
