A DJI representative mentioned that here *Introducing DJI Mavic Pro Platinum*I haven't heard that. So I'm not confirming it.
That's simply not true. DJI stated the ESC's were upgraded, they are not programmable as you imply.Disagree, sine-wave controllers are still PWM, so no hardware change required.
The new ESCs are probably responsible for most (if not all) of the added flight time.
The new ESC smooth out the power application. I guess like gentle curves vs. off on. It saves power by ramping up vs. hard throttle.
I'd like to test flight time difference on Mavic Pro with original and Platinum props.
Don't stop now, VERY interesting post. I am learning from ya [emoji1]The only stupid question is the one not asked.
We can't get down on guys just because they don't know what an ESC is. My wife doesn't know what a Master Brake Cylinder is, either, but it hasn't affected her ability to be a very good, safe driver.
Just because a lot of us here are eggheads/nerds (myself included) and not only know what an ESC is, but also know how to program them, doesn't mean that's a requirement to have fun in the hobby.
To just barely scratch the surface of the subject for guys that are still wanting to know what an ESC is, despite the clamor from the thread...
Again, I'm just gonna barely scratch the surface of this, hoping to maybe pique the interest of a few guys enough to where they search for further information. Our Mavics use brushless electric motors. In an old fashioned brushed motor, the brushes allow the motor to rotate.... ok, I'm gonna suppress the urge to go into more detail... Since our motors are brushless, they need to have something as a substitute for the brushes, the Electronic Speed Controller (ESC). An ESC is used to allow the motor to rotate through it's designed RPM range. Why brushless? Brushed motors have a notoriously short life, and are not as efficient at converting electricity to motion as their brushless counterparts.
ESC's are basically computerized switches, that switch the current on and off *extremely quickly* on the different windings on the motor. A very popular piece of software for modifying the settings in ESC's is "BL_Heli" and is available as a Chrome application.
Our motors are "outrunners". An outrunner motor means that the bell of the motor rotates. Motor sizes are designated by their diameter and height. So an 1107 motor would be 11mm across, and 7mm high. They are also designated by their "kv". The "kv" rating is probably not what you're thinking.. it does not mean "Kilo Volts". It means the no load speed of the motor per each volt of input. So a 10,000kv motor would give you a no load speed of 10,000 rpm per volt input. So, a 1107 8000kv motor is 11mm across, 7mm tall, and will give you 8,000 rpm per volt.
I'm gritting my teeth at leaving this post as it is, as there's so many "but wait, there's more!" points, and others that are generalities with exceptions that make them not necessarily true 100% of the time. But at least it's enough for guys that just want to know the basics of "what is an ESC".
Let's not beat on guys for what they don't know. Let's get them started, and encourage them to find out more if they're interested. My opinion, anyway.
I'm not sure about that. There is a setting for when you're using the rotor guards implying the profile is changed to accommodate the extra mass. During the last DJI update the MP rebooted several times - each time a different rotor twitched leading me to believe that the ESC's were being updated - likely to be able to use the new blades which appear to have a steeper pitch and are longer. No update to Go 4 yet to select the new rotors but I'm thinking there will be.That's simply not true. DJI stated the ESC's were upgraded, they are not programmable as you imply.
But that's an unrelated and separate issue. That's tuning to use the blades. We're talking about a completely different PWM waveform. Those require hardware changes to handle as they're usually not designed to handle all three different waveforms. There's usually no need to in a mass produced consumer product.I'm not sure about that. There is a setting for when you're using the rotor guards implying the profile is changed to accommodate the extra mass. During the last DJI update the MP rebooted several times - each time a different rotor twitched leading me to believe that the ESC's were being updated - likely to be able to use the new blades which appear to have a steeper pitch and are longer. No update to Go 4 yet to select the new rotors but I'm thinking there will be.
Bear in mind pure speculation on my part.
If anyone is interested in purchasing the Mavic platinum props, they are available here in the DJI Store.
I sent in an inquiry since my card was charged but no shipping info.anyone received the props from DJI Store yet? Or have you been notified they shipped? i was told 20 days to ship after payment. $10 shipping and takes 20 days to ship what am I paying for, boat fuel?
