If everyone only flew where they could actually see there drone with the naked eye then they wouldn’t be flying past 1000ft?
Hi. I looked at the cube lights and they are so expensive, I can see what you mean when you say you can get a better VLOS perhaps the lights you use are a little less expensive, I will try using ARC2 as a search and see what happens. Best regards John from sunny Cornwall.By using. Lighting such as ARC2 strobes VLOS is increased to about 2000-2500 ft in most cases.
To OP... beware of hanging cables, rope, etc. scout the area when possible before flying close.
BTW ... Binoculars don't satisfy VLOS requirements. Eye glasses and contacts are the most "aid" that you can use.Agreed. Still you can get closer and use binoculars, etc.
Agreed,...my post was about scouting areas before flying to avoid things like the dangling cable or rope imaged above.BTW ... Binoculars don't satisfy VLOS requirements. Eye glasses and contacts are the most "aid" that you can use.
According to Section 107.31 -
(a) With vision that is unaided by any device other than corrective lenses, the remote pilot in command, the visual observer (if one is used), and the person manipulating the flight control of the small unmanned aircraft system must be able to see the unmanned aircraft throughout the entire flight in order to:
(1) Know the unmanned aircraft’s location;
(2) Determine the unmanned aircraft’s attitude, altitude, and direction of flight;
(3) Observe the airspace for other air traffic or hazards; and
(4) Determine that the unmanned aircraft does not endanger the life or property of another.
I use 4 Firehouse ARC2s, one on each arm; 2whites on rear arms and then a red and a green on each front leg ... all in Aerial Pixel mounts no Velcro or adhesive needed. These have over 600 flights on them since Dec 2018. As mentioned above, this also helps visual recognition of drone orientation. Never a camera problemCubes are more for lighting, huge and heavy !
The Firehouse Tech ARCIIs are the go
Still on special I see.
Hope the little switch problems have been sorted by now ??
You can find threads on this forum by searching > Firehouse ARCII (or 2) LED
This is a popular set, red and green on outer front arms, white at rear, std nav setup for knowing orientation.
Aerial Pixel (a member here) makes arm mounts for these, but you can velcro on for remove and replace (I'd use a dob of urethane adhesive under the mounts to the arm and led though for extra security of the adhesive).
I use 4 Firehouse ARC2s, one on each arm; 2whites on rear arms and then a red and a green on each front leg ... all in Aerial Pixel mounts no Velcro or adhesive needed. . . . Never a camera problem
You can move the Aerial Pixel mounts for the lights as there flexible. A set of 4 for back arms and front legs is $13.00 U.S. plus shipping. Your U.S. contact could mail them... they are only good for M2P and Zoom... each model has it’s own type of mount. One thing about the mounts offer is protection for the circuit board. Just FYI. Details are here;They look good there Thomas.
I plan to use the same setup pattern with nav lights red / green on front legs (pointing slightly outwards), and 2 white on the back arms.
I'll use velcro though, as I can place the loop tabs on other drones and swap the one set out to another drone as needed.
The other thing with mounts is they are so exy here in Australia, think the set (2) on Firehouse page are around AUD$25, so $50 a set (for use on one model drone) is just too much.
Better priced than the nice angled ones though, like available here in Aus from Perth Drone Shop . . .
AUD$44 is about US$30 !!DJI MAVIC 2 PRO ZOOM ENTERPRISE ARC STROBE MOUNT SET - Drone Shop Perth
DJI Mavic 2 Enterprise Front or Rear Strobe Light Mount Set (Strobe not Included) Professional designed, US Made Strobe Light Set for DJI Mavic 2 Series Including Enterprise DJI Mavic 2 Pro Zoom Enterprise series mounts for the Firehouse Technology Strobe Light Series. Designed and made to snap...droneshopperth.com.au
Firehouse don't ship to Oz either, but I am getting some sent over via a relative there.
So good to see (FHT just confirmed for me) the switch problem is totally resolved, they do very rarely have a bad lipo in one here and there, they said, but fingers crossed this won't happen too often.
Wow what are you viewing that on, a 65” HDTV? I see none of that detail on my phone.This wire:
Catch that just right and you turn your drone into a permanent wind chime.
Absolutely! What's really dangerous for us daredevils are those cables and very hard to see fishing lines!Agreed,...my post was about scouting areas before flying to avoid things like the dangling cable or rope imaged above.
And what's nice, you can use them with the PolarPro leg extenders...I use 4 Firehouse ARC2s, one on each arm; 2whites on rear arms and then a red and a green on each front leg ... all in Aerial Pixel mounts no Velcro or adhesive needed. These have over 600 flights on them since Dec 2018. As mentioned above, this also helps visual recognition of drone orientation. Never a camera problem
