hiflyer201
- Joined
- Sep 27, 2018
- Messages
- 2,679
- Reactions
- 2,120
Actually only 2 batteries..I couldn't get it to request the download for the third battery. I'll have to keep trying
I am more attached to my SC than to my Mini. I don't really need a Mini2, it can do nothing that my MA2 cannot do. If it worked with the SC I would reconsider though, due to usability-factor.What an immature statement.
Some of us own multiple drones and using the SC for all of them just makes sense
Hopefully that will change with complying with the new RID requirements.I've had the Fly Spots option in DJI Fly for Android since getting my Mavic Air 2, however it doesn't seem to offer any locations in the USA. It might be only functional in the Chinese market from what I can tell.
Thanks for this and for your service.Went to do something this morning on SC and got the prompt on the new update (OTA)...not going to do it (President Bush voice).. I can find no info on this new firmware (DJI...ect).....anyone???? on screen it just says on details...Improves overall stability... I mean... What? Mine is already "Stable". Thought for sure it might have been Mini 2.
Well crap...taking a hit for the team...updating now OTA.
My Sequence:
Download went smooth...short hang at 99% 2(ish) minutes
Install hung at 16% for about 4 minutes
Install hung at 98% for about 2 minutes
Screen Message: Firmware Updating, Checking the Package, going to reboot (Or to that effect)
Reboot...seemed to be New DJI Screen? Had a swish of blue swirl/shadow...Kind of like sunflare?
Message: Initializing system update
Multiple screen resets with a load bar (About 3-4)
Reboot to home screen
Zero errors for me using OTA (Not Asst 2)..went through first time, note it says you MUST have more than 3 gigs empty....YOU HAVE BEEN WARNED by DJI this time newbs
What I have found so far:
As mentioned Fly App update 1.2.2
Go 4 version 4.3.36 (Don't know if that changed?)
Some new program called "Fly Spots". Which appears user based for "us guys" to use global maps to relay to other users POI's..in our areas..kinda like Litchi does I guess?
I now have a little white block in opening screen, top left corner that I have no idea? I thought it was a system message but does nothing when I press it..any help with that one?
So yeah, will update on this thread if I find anything new.
the battery you used to do the drone’s FW update would have been updated during that process, but it doesn’t tell you that it has been done.Actually only 2 batteries..I couldn't get it to request the download for the third battery. I'll have to keep trying
I never experienced this issue with the last firmware. Both my M2P and MA2 flew fine, so I’m not sure everyone had that issue.Has anyone tried the M2P since the SC update. An earlier FW that added the MA2 to the SC worked well with the MA2, but then caused a lost link with the M2P at shorter distances. There was an earlier post but no one in that post found a solution. Have not flown my M2P since due to the disconnect issue.
I’m staying away from all future updates. One of these times dji is going to pull a sneaky one and slide in more restrictions. I’m still scared when they took out the “rollback” feature.Went to do something this morning on SC and got the prompt on the new update (OTA)...not going to do it (President Bush voice).. I can find no info on this new firmware (DJI...ect).....anyone???? on screen it just says on details...Improves overall stability... I mean... What? Mine is already "Stable". Thought for sure it might have been Mini 2.
My Sequence:
Updated mine with no problems! Love what you wrote!Went to do something this morning on SC and got the prompt on the new update (OTA)...not going to do it (President Bush voice).. I can find no info on this new firmware (DJI...ect).....anyone???? on screen it just says on details...Improves overall stability... I mean... What? Mine is already "Stable". Thought for sure it might have been Mini 2.
My Sequence:
You are right about the noise, but maybe a bit too optimistic about it?
I noticed the advantage of less noise with birds in my river shots, compared to my M2Z, which I have lots of experience. I can get much closer to birds with the Mini2, and other animals too. You can try this yourself if you have a lake or river nearby, maybe with small birds, ducks or geese. Try to get shots like mine up close with your MA2. It's pretty amazing how the Mini2 allows closer proximity to animals before they get spooked. I think it's not only the low noise, but the smaller size that appears less intimidating, plus harder to see.You are right about the noise, but maybe a bit too optimistic about it?
My experience:Thanks Repaid 1. Tried the update and had multiple fails at 16%. Recalled something from another thread about not trying to update with an SD card installed. Removed the card and the update went through as you described.
