What’s your affiliation to this company?Hi guys it´s of topic but I feel it is woth to share.
New V shape two rotor drone with DJI spec and 50 min flight time!
gethover.com
Check it out, it looks like real DJI competition.
zero zero robotic V-Coptr Falcon
Probably they’re the Director of Marketing, but as has been noted, the drone is an interesting one, worth discussing. Granted, the absence of a disclaimer could be considered shameful at the very least.What’s your affiliation to this company?
just came across it at the FlipperWhat’s your affiliation to this company?
And you felt compelled to create the account, just today, on which the above is the second post (the first being the plug itself). The jig is up, as they say, although that idiom may be unfamiliar to you.just came across it at the Flipper
Yap, just today broAnd you felt compelled to create the account, just today, on which the above is the second post (the first being the plug itself). The jig is up, as they say, although that idiom may be unfamiliar to you.
As I said, I think you made an appropriate post, and don't care if you're the Director of Marketing for them or if you're just a bro who parachuted in here carrying a banner.Yap, just today bro
I just like V- Copter design that’s all to it.
Did I offend you with that?
It’s probable the associated drone would have gone out of control if the tilt-rotor mechanism failed in flight. So the drone will likely need other repairs if those gears need servicing.I think that all those gears would be extremely hard to replace or fix.
Yes, I don't see how it could stay in the air with just one prop; if you're 100ft up, the damage would be extensive. I see what you mean. I wonder if Zero Zero is going to have a Care Refresh-like program so you have a fallback if you do crash.It’s probable the associated drone would have gone out of control if the tilt-rotor mechanism failed in flight. So the drone will likely need other repairs if those gears need servicing.
Failure of the tilting mechanism wouldn't necessarily affect the motor, so the drone would likely remain airborne. You just wouldn't able to control it.Yes, I don't see how it could stay in the air with just one prop; if you're 100ft up, the damage would be extensive. I see what you mean. I wonder if Zero Zero is going to have a Care Refresh-like program so you have a fallback if you do crash.
I wasn't really talking about the servos; I was talking about the gear-train system. If one of those gears were, say, stripped out, the it would affect the motor for sure, such as the rotor speeds, balance, all that.Failure of the tilting mechanism wouldn't necessarily affect the motor, so the drone would likely remain airborne. You just wouldn't able to control it.
Best case I can imagine is that it just flies in a circle or it spins around. So even a "controlled" landing is necessarily a crash.
Quads don't have this mode of failure.
