New Mavic 3 Classic pilot from Lyon-France : Hello!
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
As a new owner/user of the Mavic 3 Classic
Since you live in France, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Happy Droning…
Salutations, Fred, et un Big Texas Bienvenue sur le forum!
The Mavic 3 Classis will get you vids and stills you only dreamed of with only a ground-level camera. This forum is a great place to get help as you grow as a pilot and photographer. Can't wait to see some of your work!
Rich R (AKA Hauptmann) from North Texas
dronesforlife
