New Mavic Low Noise Props - TESTED - Longer and quieter ?
I can confirm the MPP props on the MP is noticeably quieter. I can hear my MP from further away with the original props. What i did notice..the MPP props have a lower frequency (Hz) than the MP props. The only down side I noticed was the MP is a bit slower flying into the wind with the MPP vs original MP props. Personally I prefer the MPP props..I like the way they sound, and the fact the sound draws less attention.
Reactions: mfc
I have found them quieter. But have now given up on them. Kept getting bad vibrations - even with a 2nd set.
Reactions: edmonds217
If by vibrations you mean gimbal shaking, then I get that too. it usually goes away after a few minutes with full on altitude accelerations in sport mode. Once it comes back down shake is gone. At least for me.
Just watched a YouTube video on that go into settings and change the sensitivitys to 89 instead of the 100 that's by default only do this with Platinum props.
If you change back to original props be sure to change back to 100
Basic gains you can leave vertical at 100
You can go higher than 89 but that works good
Good deal like I said you can play with those numbers to find your likings
Purchased 2 sets from different ebayers and both shake the cap out of mavic.
Will just keep buying originals and from dji
Steve try what post 90 says won't hurt to try
I put them on last night changed the gains and it worked.
jacjes
