New member thought I am registered?
Hello from the Crossroads of America yuke.
Registered...
With the Forum? Yes , we see your post.
With DJI? Don't know.
With the FAA? The Mavic mini 1 doesn't need to be registered as a recreational pilot since it's under 250 grams. If flying anything other than recreational (business), then part 107 certification and registration would be required. You can still register the mini 1, it's only $5, and if you add something later to the aircraft to make it heavier than 250 grams, you'll be covered.
Here's a link to the FAA's Drone Zone if needed.
Regardless of what you're flying, you should take the TRUST test and keep a copy with you when you fly.
It's a free, no fail test that's easy to take with basic knowledge of flying a drone.
Good luck and welcome to the Forum. :cool:
Yes, your on the system :)
As: Meta4
Stated: "Ask away"
Questions, start a thread here: Mini 1
If something doesn't work reply here. The members are great!
BTW, There is search option at the top, I usually scroll up.
Rod
Hello I thought I am registered but not sure? Can anyone see thus post? I flew my Mavic mini 1 couple times now and have some questions about it .
Welcome back, You have been a member since December 2020 and this is your third post…
Any case…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Indiana, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
brokerman
