New member
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. The good news is you have a drone with advanced GPS and obstacle avoidance so you are 50% there. I suggest 'beginner videos' on YouTube to get the basics. I'm assuming your reading is on the current laws and regulations for sUAS pilots. TRUST Certification is a must. Others will chime in. Good luck pilot . . . !!
Welcome to the forum! :)
Welcome to the forum from the beautiful woods of Maine!
Flytpath on YouTube has a good series of videos from unboxing to your first flight, check them out. There’s many knowledgeable members willing to help you with any questions you have. As dirkclod said, search the forum, use key words, and if you don’t find an answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Welcome to Mavic Pilots! :) Enjoy the forum! Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
As a newbie, do not let the excitement of the moment get the best of you. When you are going out to fly, do it slowly and deliberately. Get used to a set procedure and even practice it.
Happy Droning
Hi everyone.
Newbie from Nanuet NY
I just bought an air2s on this forum from another member a true gentleman
Btw I have zero experience😀
I did a lot of reading but i need a heck of a lot more
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
Noobie
