New Pilot from Laveen AZ
Hello from Minnesota and welcome to the Forum....Congratulations on your drone (Mini 2 or Air 2s?)...There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safely and fly smartly representing all of us drone hobbyist well.
There is so much to learn I'm sure I'll be using this forum for advice. Thanks
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Arizona, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Fly On and Fly Safe…
Lotta good advice there. I didn't think of looking on YouTube for the bloopers. I have been watching a lot of videos from experts on how to do different things with the drone. I try and get out most days for half an hour or so just a practice different moves and it's getting easier. I'm trying to learn in a step-by-step systematic way so I don't get ahead of myself. Thanks for all the help.
Welcome to the forum! :)
Laveen? I would be more afraid of getting shot than flying a drone there
We aren't trying to make a political statement here, are we?
cjd54
