New to the forums.
Welcome to the forum! :)
New to the forums here from Texas.
My first personal drone was the GoPro Karma Drone and have since bought a Mavic 3.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Fly On and Fly Safe…
Thanks for the information.
I wouldn't really say I'm new to drones as I fly some for work. Currently for work I use the M300 w/ the H20T and the M30T.
Now as far as using drones for fun, I would say I'm new. Looking into getting into video and photography editing with my Mavic 3.
YouTube is a Great source for instruction, ideas, and entertainment, Good Luck and FLy Safe.
Hello from the Crossroads of America MikeTX
Welcome to the Forum. :cool:
instaproapk
