Newbie from Sarasota FL area!
Welcome to the forum from south central Florida :cool: and enjoy. 🌴
Plenty of locations to fly in the center of the state.
Hi guys, just wanted to introduce myself. I am a newbie to drones, and just purchased my Mavic Pro Platinum. I've had about a total of 20 minutes of airtime with it until my next day off work, so I am hoping to learn lots from this site!
Purchased my Mavic from Costco. It came with the dji goggles, and the prop protectors. It was on sale for $1,099.00. Sounded like a good deal with the goggles!
Any others in the Sarasota area that can recommend some good places to fly? I actually live in Nokomis, for those who might be local.
Thanks for letting me join, look forward to learning all I can.
Rick
Hi, welcome to our lovely oven. Well, it feels that way.
I live just north of the airport (SRQ), and worse, in a zero grid. Therefore I have 3 places to fly: 1. Indoors. Ok for the Avata, but not so much my camera drones. 2. My large pool cage. This counts as indoors, since it's not controlled airspace since it's under my pool cage. Ok, if boring with my camera drones. I've set up an 'obstacle course' in my pool area that's sort of fun with the Avata. And, finally 3: Anywhere but near my house or the zero grids around me.
Sure, I can apply for an altitude waiver, but not with LANNC, and it takes weeks to usually get denied.
All this being said, there ARE places to fly around here. The City and County of Sarasota isn't really tough on drones in city and county parks. Bradenton and Manatee County are less welcoming, but they have little or no legal standing to prohibit drones.
If you want to get together for some flying, I'd be up to it. Welcome! - Jeff
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic Pro Platinum, including the User Manual.
Fly On and Fly Safe…
Reactions: wjkrysak
canuckdive
