Good Morning From Central FL
Dave MH
Central Florida
Time to get active on this forum, sold my EVO II Pro and am now the owner of a AIR 3.
FYI, started flying quad copters (drones) in 2013, so not a newbie!
Very new to the DJI Universe and have to learn how to deal with DJI's oddities.
Be kind if I ask a question that you veterans know so well.
My biggest concern is my first encounter with DJI's geofencing.
Flew this morning for the first time (with DJI Air 3) in a remote / private area.
It was a perfect morning to fly!
All went well, but can tell I've got a lot of new stuff to learn, practice makes perfect.
Great choice! I haven't tried the EVO II Pro, but the Air 3 is a very nice drone.
Since thngs might have changed since you last flew... there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Welcome to the form from Tampa!!
Congratulations on getting an Air 3. All the best with it. Please join us at the 4th Annual South Florida Drone Meetup in Jensen Beach, FL on April 6, 2024 and join our fb group too.
dronesforlife
