Newbie from SW Scotland
welcome to the forum,as the Mavic air is now a legacy drone it can only be flown in the Open A3 category, unless you have the A2 C of C
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. We look forward to your participation and your view of the world.
Hello from the Crossroads of America notadrop
Nice to meet you Paul. 🤝
Welcome to the Forum. :cool:
Just joined and intending to buy a Mavic air 2
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2, including the User Manual.
Happy Droning…
Happy Droning…
Well that is, truly, very informative and greatly appreciated Loud Thunder!😁. I have now in fact just purchased an Air 2 S rather than the Mavic Air 2. Much reading and You tubing to do as I am a total greenhorn and don't want to **** it up first go! Will follow your guidelines for sure and make in my routine every time 😁👍
Well, we'll fix that...
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
happy and safe flying...
Reactions: dirkclod
Again brilliant and thanks LoudThunder (have you a Harley?
No
No worries mate, just wondering about your handle, is that a New Year resolution. 😀
Regards
Haha. Many years ago I was with a group who wanted to move on from a bar. I mentioned I hadn't had a drop in 2 whole weeks and fancied another. A mate piped up 'what? Not a drop?' It all went downhill from there! Back to today.....l hardly touch the stuff 😁
  • Haha
Reactions: Gagey52
Maccer
