No other way to downgrade Mavic 2 firmware from 0790 to 0770?
Perhaps you should tell us what you have tried, until then how can we tell you of others methods ..... if there are any?
Reactions: JC_Wang
You can use Drone Hacks to downgrade the Mavic 2. Need to download the FW via Dankdownloader and then install via drone hacks
Reactions: JC_Wang
I tried that already, but the ARB # of 790 is 2 and 770 is 1. So no way from there.
Reactions: Yorkshire_Pud
You have almost answered your question yourself.
You are aware that there is now data in your drone that prevents downgrade of your firmware.
If you could change that data then you could downgrade the firmware.
The problem is that in order to change the data you need access to the root and you do not have access to the root.
If you search the internet, you will find core boards for sale at a premium price, with root access that would allow you to downgrade.
However if you swap the core board then you will effectively have a different drone.
Reactions: JC_Wang
Andrefu
