Obstacle Avoidance
Lam Nguyen
How does it really work? I try testing it and fly close to a tree and the remote vibrates around ~8ft away but it doesn't come to a halt. I can still fly forward closer and closer to the tree.
Is there a way to set a warning distance or is there an option to have it stop completely even if you try to force it to go closer?
Thank you in advance guys!
Trees are tricky. Since they aren't a solid object the Mavic may miss the outer branches. Same is true of thin objects like power lines. Obstacle Avoidance can help but you shouldn't count on it.
ICantStopTheLoneliness
