Parameters for change Front Leds light to solid red color. ( from standard green and red intermitted )
fammi
Hi,
I preferred the old solid red color on the Front Leds as used on M2P and M2Z.
The Mavic, has an intermitting green and red lights.
Do you know, which parameters, could be changes to fix it into a solid red color ?
THANKS,
Fabio.
I asked a similar question in the Software/Hacks forum. No replies as yet.
I was hoping someone had some insight to the Drone Hacks program.
Reactions: Reactor2015
There is plenty of insight into the Drone Hacks program.
However, with thousands of DJI parameters, most of the parameters focused upon by others have been related to FCC range, NFZ's, height limits, ascent and descent speeds, Autolanding, and Smart Go Home, rather than the front and rear lights. Most of the parameters have relatively appropriate names, and you can search all parameters for matching specific words or phrases, to play around among the matching results of your search.
devilsown
