To fly an ultralight you do not need a license, nor must the aircraft have an airworthiness certificate nor be registered with the FAA, but would be stupid to try and teach yourself to fly it so you should get proper training.I was once told there wasn’t any requirements to fly an ultralight or powered parachute. No aircraft registration or license needed. Has that changed? If not, wouldn’t you agree that sort of makes all this drone stuff pointless doesn’t it?
Even the parachute can be an ultralight. Under the FAA definition, they do not call it an aircraft, it is an ultralight vehicle. So basically anything that takes to the air under power that weighs under, read that again, under 254lbs empty weight, has no more than a single seat and carries no more than five gallons of fuel (technically you are not even allowed to carry a spare fuel can with you, with any fuel in it) and makes the legally required minimum stall speed and max. straight and level flight speed under full power, is an Ultralight. Does not matter if it is a fixed wing, rotor wing, flex wing or parachute, if it meets those parameters, it is an ultralight. You still need to obey all the FAA air laws though.I am pretty sure that was the case last time I checked. I had a farmer friend that wanted me to help him assemble an ultralight. He got the parachute instead and flew it all the time.
Also. What about the fixed wing RC question. Do those require registration?
Thank you for you patience!
I’m with you. It’s ALL about compensation.Sorry to disappoint you - both sport and private pilot licenses are restricted in terms of compensation.
When you take your powered parachute up you have to abide by the laws set up for flying in the NAS. Also you can have a much better situational awareness when you are in the aircraft, compared to looking at a screen from a fixed position of a camera on board that UAV. Also, if you were to take a photo from your Powered Parachute and tried to sell it, you would be breaking the law because you do not have a commercial pilot license, so basically... No Change Here!I know what they are trying to do, I wonder why they bother when they don’t care if I take my camera to 1000 feet on a powered parachute.
Did you want to say Except or Accept, those two words mean very different things and would completely change what your paragraph is conveying?I get that you except the regulations. I am arguing that the regulations are not fair and should be changed. It seems like the FAA saw a cash cow and took advantage of it.
The cost of setting up, keeping records and running such a department with staff in such a giant organization as the FAA will, I am sure, far exceed the small amount of money they are actually taking in.That doesn’t make them right. $5 times how many users? That’s quite a little money in fact.
With that said, when you do leave the ground in your ultralight, you are still legally bound by all the laws that every other licensed pilot is bound by. So your argument comes crashing down. You must follow the laws that are in place by the FAA and airports that are not taking federal funds to help them out, can also ban you from taking off or landing at that airport if you are in an ultralight. Most don't do that but some do. It is not as simple as you seem to think.
in a nutshell, the FAA leaves it to the discretion of the person with the Ultralight then?
We all agree that only an idiot would fly one without training, but we also know that they do it ALL THE TIME.
Without the FAA requiring a registration number, or a licence , or any restrictions on what the "intention" of any flight is.
_________________________________________________________
The FAA does require an ultralight vehicle to fly in accordance to the laws that all other licensed pilots must abide by, but the FAA does not require a true ultralight to have an airworthiness certificate, nor annual inspection, nor registration, neither does it require the pilot to be licensed or have an aviation medical. There are plenty of cases of people trying to teach themselves to fly and many deaths and injuries resulting from such attempts. Is it possible? Yes, it has been done but not a lot of people are that stupid or are that lucky to survive such actions. I think you will find that most of those engaged in Ultralight flying have gone the sensible route and taken flying lessons to get where they are. There are still idiot, but trained, pilots out there of course in both ultralight and GA areas of flying. As for restrictions on what the "intention" of any flight is, what do you mean exactly? You can go up and fly around having fun with any intention you want. You still have to follow the same laws as any other licensed pilot does though concerning how, where you fly and what airspace you fly in and time of day.
What you legally can not do, is fly where you are not allowed, over places that you are not allowed to fly over, at altitudes you are not allowed to fly at and of course you are also not allowed to use any ultralight for commercial use because the FAA never created a commercial use for ultralight flight. Same in GA you can not have a private pilot license and fly commercially, as in go up and take photos you intend to sell or accept money for taking someone for a flight for example, not legally. Though some people do actually do it, it does not make it legal.
You also wrote:
My drone meets EVERY ONE of the ultralight regs. Less the single seat rule, which should be even a better reason to treat drones as ultralights.
Answer: NO, no no, because you have four engines and an ultralight can only be single engine and even if you find a loophole, as you rightly pointed out, it is a vehicle designed to carry a single person and is not allowed to fly without a person at the controls, so you are not even close. Nice try though.
You also wrote:
Laws of AIRSPACE ONLY, The common sense ones.
It says nothing (that I could find) in the ultralight rules about photography or commercial use.
Answer: You need to understand manned aviation a little better, there are exact laws that pertain to commercial use of an aircraft, the pilot MUST be a commercial pilot, to carry out commercial operations, such as photography to be sold, or flights for hire, as in being paid to take someone flying. There is absolutely no commercial application allowed with an ultralight, it is clear as day and if you still think it is possible, just call your local FAA office and they will make it perfectly clear to you that you can not, and I'll say it again for you, can not use an ultralight for any commercial application. It is common knowledge to any real pilot, as in one who sits in the aircraft and controls it in flight.
You also wrote:
I typed it, you understood it. That my friend is "Affective" communication. Nit picking is not a trait to be proud of.
I understood what you typed but was not sure what you meant, that is why I asked, since you could use both words in a response such as yours, but the words in question would have very different meanings. Not making things clear with the words you choose, when you respond to a post, is possibly not a trait to be proud of. Nit picking has nothing to do with it, it was clarification requested, not nit picking, I believe you misinterpreted.
You also wrote:
They are already set up. We are talking about the FAA. They have controlled aircraft and regulations for what 100 years? What setup are you talking about? Just the new drone web portal and an account to deposit the funds?
So it sounds, things are a bit overheated when it comes to taking pics in the US.
Here in Germany you only need a license to fly, if your bird is over 2kg in weight (More than the usual Mavic, Phantom or similar).
And yes, you can sell your pics as long as you have the mechanism in place to give the taxmans their fair share.
Of course we have pretty strict (sometimes ridiculous) flight restrictions, which anyone has to adhere to though.
I do not understand that 107 thing in the US. Why should a pro operator need to have more knowledge than the amateur flying the same bird???
Now the (a bit hypothetical) question, what happens when I cruise on my, in Germany registered, sailboat to the US and would have a YouTube channel generating a small bit of income from documenting my cruise. Especially if I'd use my drone to document this.
Let's assume I am NOT filming for other people or businesses.
Is the drone license treated similar to a captains license?
If your country of citizenship does not require you legally to have one you are not required to have one. On boats you are always bound by the legal requirements of the country of registration/captains citizenship.
Do I need a 107 license then?
Thanks, but, obviously it would be the intention to flight also in the US in line with local flight restrictions.
Still, I am unclear how that 107 thing can be applied to foreign aircraft flown by foreign pilots for the benefit of a foreign person.
Pretty sure someone with a foreign pilot license flying into the US does not need to retake their exam.
So, how does that apply to drones?
I'm British with a pilot's license for private use, so British PPL. If I fly to the USA, I just fill out the documents to enter the US airspace when I make out my flight plan. I can fly around the US on my British license before departing to the UK. I must follow all us laws related to flying in US airspace.Thanks, but, obviously it would be the intention to flight also in the US in line with local flight restrictions.
You dont seem to understand my line of thought. It is NOT that I dont know what the FAA expects. That is clear to me. It is just over reaching when applied to flying toy cameras. I know people dont like the term toy, but a toy it is. people are just using them professionally.You wrote:
post: 576879, member: 35899"]in a nutshell, the FAA leaves it to the discretion of the person with the Ultralight then?
The FAA does require an ultralight vehicle to fly in accordance to the laws that all other licensed pilots must abide by, but the FAA does not require a true ultralight to have an airworthiness certificate, nor annual inspection, nor registration, neither does it require the pilot to be licensed or have an aviation medical. There are plenty of cases of people trying to teach themselves to fly with many deaths and injuries resulting from such attempts. Is it possible? Yes, it has been done but not a lot of people are that stupid or are that lucky to survive such actions. I think you will find that most of those engaged in Ultralight flying have gone the sensible route and taken flying lessons to get where they are. There are still idiot, but trained, pilots out there of course in both ultralight and GA areas of flying. As for restrictions on what the "intention" of any flight is, what do you mean exactly? You can go up and fly around having fun with any intention you want. You still have to follow the same laws as any other licensed pilot does though concerning how, where you fly and what airspace you fly in and time of day.
What? You think there is only a web portal and an account set up? You don't think there are staff assigned to do that work and keep records, flie reports and monitor that sector? I think you will be surprised how big that section of the FAA is becoming, and surprised to learn that people doing other jobs for the, as you put it "100 years" have enough to do carrying out their assigned duties, which for the last 100 years had nothing to do with drones. Hopefully you understand and can appreciate this a little more now.
Ahhh, I was meaning that if you were flying an aircraft yourself, not a drone. However, that is good to know that you can do it with an under 2 kilo drone, gut fuer euch Deutsche, schade fur uns! Thanks for the clarification.Thx.
No, thankfully in Germany a German drone operator is free to use images commercially as long as the taxman gets his share and the bird is below 2kg.
Apart from the type of insurance no distinction between commercial and not commercial below 2kg.
Commercial insurance is needed for commercial work.
You can buy commercial insurance on a per day base (about 10€).
Things might differ if you want to fly for public projects (railroad services or the like).
Above 2kg any pilot needs a license, private and commercial.
At some locations you need to get flight permissions before take off. There is a great app from Deutsche Flugsicherung DFS indicating where you are allowed to fly.
Thanks for the tip about DFS, that will be a great help the next time I'm over there. Do you know if there is anything similar for Austria?Thx.
Ohhh I'm with you 100% on the toy thing but regulating it like a real aircraft, the problem lies, I believe, in the fact that they have become so simple to fly. That means anyone can go out and fly it now and some of those or possibly many of those people are inadvertently or blatantly breaking the laws whether they are aware of them or not.You dont seem to understand my line of thought. It is NOT that I dont know what the FAA expects. That is clear to me. It is just over reaching when applied to flying toy cameras. I know people dont like the term toy, but a toy it is. people are just using them professionally.
Rc airplanes went unregulated and without issues for many years, until drones came into play. Before there was even ONE claim of near miss or collision, everything is regulated like manned aircraft? And they lumped in all flying RC toys to boot.
When the FAA says my INTENT has to be either commercial or recreational before I fly BUT, they then say the RESULTS of the recreational flight are not subject to the commercial rules. (in so many words.) That makes NO sense. And is unenforceable. That is what I am saying.
The device will record audio of the pilot so if one says "this is a recreation flight for fun, there is no intent to use its result commercially" on the flight recording. That proves intent.
In the cases that the FAA is reported to be pursuing, the people are ADVERTISING aerial photography. So let them be called commercial.
Not flying around aircraft or airports, or over crowds should be common sense. That is pretty much all they are asking of ultralights and the like. That is all they need to ask of drone pilots.
Their registration of either 336 or 107, or anything else, is NOT preventing anything, and never will.
it is a waste of time and resources. Aircraft damage should be covered by insurance like car damage, death should be treated the same way. It wont add a noticeable amount to airplane insurance because IT ALMOST NEVER HAPPENS! And the couple documented times it has occurred it was without serious damage.
I KNOW how it is, I am saying its STUPID and saying why I think so.
