Pay for DJI Fly app???
Welcome to the forum and the hobby SirMichael.
Since you seem to be fairly new to the hobby (although I could be wrong, and I don't mean this in a derogatory tone, we all have been new) I thought I'd mention a few items. Are you aware of the requirement that all pilots review and take the TRUST exam: https://www.faa.gov/uas/recreational_flyers/knowledge_test_updates . It's free to take the trust, and there is some good information for new folks.
Also if you are flying anything over 249g (.55lbs) you have to register it on the FAA Drone Zone: https://www.faa.gov/uas/getting_started/register_drone . The basic Mini 4 Pro is under .55lbs but if you add anything (including the extended battery or propeller guards) you will go over that weight and need to have it registered and have your ID labeled on the outside of the drone.
Have fun and fly safe!
Greetings: welcome to the forum from Chicago the Windy City.
FLY SAFE & FLY SMART
Reactions: LoudThunder
I just purchased a DJI Mini Prio 4
You have already gotten lots of advice that you do not need to pay to play,..
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Minnesota, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Reactions: MA2 317
The Android operating system has no control over what apps are written and distributed. It's up to the user to ensure that they're downloading the right app from the right source.
Friction between app developers and the app stores is common.
Would you post the link where you saw the bogus Fly app? It might help others avoid the same problem.
I had the same issue with mistakenly downloading the spoof app from the Google Play store. The clue is the cheap-looking gold star crown labeled "Premium" and the absolute inability to avoid the come-ons to pay. I'm going to wipe my tablet clean and download direct from DJI.
  • Wow
Vlad_Zherikhov
