Pilot Check IN
Welcome to Mavic Pilots! :) Enjoy the Forum!Thumbswayup
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Hello all from Leicester, England, experienced R/C helicopter pilot, but a Newbie to drones
Hello and welcome to the forum from the Colorado Rocky Mountains! Happy and safe flying!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in the Uk, there are specific laws and rules for you to follow, please check to ensure these are current.
Tell us what type of Drone you have and perhaps we can hook you up with some great downloads… As they say, "Inquiring Minds Want to Know…"
Now, for some Good Old Fashion Advice. Sorry, it's DJI Specific…
Happy, Safe and Legal Droning…
Welcome to the forum! :)
PilotOne
