New to the furum
Hello from the Crossroads of America kevstar.
The weather will break at some point, be patient. :)
Welcome to the Forum. :cool:
Hi all. I'm kev and live in Whetstone leicester I've got a dji mini 4 pro. I've had the drone a while but not really had the chance to get out with it with the weather or work commitments. I'm hoping for better weather to get out there and capture some good videos.
Hola,
Had a fun weekend in Leicester with a bunch of mates last summer :)
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Greetings Kev: Welcome to the forum from Chicago the Windy City.
FLY SAFE & FLY SMART
Reactions: LoudThunder
Welcome to the forum from south central Florida :cool: and enjoy. 🌴
cjd54
