Polar pro phone mount or freewell ?
Sav
Western Australia
Hi I’m looking for some advice from people that have used both the above mounts on the mavic 2 controller . Which did you prefer ? Which was a better design and user experience.
Thank you
Thanks for the reply I would prefer the phone up the top similar to a phantom position as that is what I’m used to flying and have just moved to the mavic 2. That way I can still see the controller screen to.
This aspect of what can or needs to be seen has gone on for years. There are some that can’t live without what is on the rc, and some that get what they need from the screen on whatever device they use. In reality, the only info on the rc screen that is critical, is the battery info for the rc itself. The rest shows up on the device screen.
Reactions: Former Member
Are these the two mounts you're considering?
PolarPro
Freewell
If you're using a phone that's in a thick case (like an Otterbox Defender), then the mount like the style @Thunderdrones drones posted above would likely work better. It'll fit a tablet too (if you ever fly with those).
Reactions: Sav
Neither PolarPro or Freewell offer the measurements for their mounts. I measured the Freewell mount with calipers and it'll hold a device that's up to 12.5 mm thick (including the case). Perhaps someone else will chime in with the PolarPro measurement or you can try contacting them for help.
Reactions: Sav
You can try this one. Works with phone or tablet.
Search for this on Amazon:
Fstop Labs Remote Controller Device Holder for DJI Mavic 2 Pro Zoom Enterprise Foldable 4-10 Inch Phone Tablet Extended Mount + Neck Strap Accessories
Reactions: Sav
joel_du05
