présentation
Translation:
hello everyone my name is odofi and I am new to this forum. Thank you for welcoming me here
Hello from the Crossroads of America odofi.
Welcome to the Forum. :cool:
Bonjour du Carrefour de l'Amérique odofi.
Bienvenue sur le Forum. :cool:
As you might have noticed, some of the members took the time to translate your greeting… We are basically an English speaking/writing web site and you might want to use Google Translate in the future…
Since you live in France, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Welcome to the forum. We look forward to your participation and your view of the world.
aodgizmo
