- Joined
- Oct 20, 2016
- Messages
- 72
- Reactions
- 41
- Age
- 52
Possibly a daft question but does precision landing work at night using the landing light?
Haven't seen anyone say yet as it is still early with this update .Possibly a daft question but does precision landing work at night using the landing light?
Hi, are you flying your drone at night because it is illegal.
Thanks for that officer dibble
What does that mean? Be sensible and don't get yourself prosecuted or give sensible drone flyers a bad name. Thanks.
Who are you to point others pilots what they should or shouldn't do, you don't even know from what country he is from !?What does that mean? Be sensible and don't get yourself prosecuted or give sensible drone flyers a bad name. Thanks.
When you take off your light comes on and landing it comes back on when close to ground at night.
Is drizzing here so will try later but did try this afternoon and took off from here
View attachment 54263 went out and RTH and landed here View attachment 54264 Now was taking off in rocks so no target
but only off a few inches. Really doesn't matter to me as I hand catch almost every time so just checking to see .
Did it do the hover at 5 ft even with the stick pulled down to override the landing caution???To prevent any problems, I am in the US, and I do have a Daylight waiver and legal to fly at night. I flew my first nighttime flight the other day with my new Mavic 2 Pro. When landing it came down to 5 feet AGL and would not decend any further even with the sticks. I tried going up slightly, then back down again, it would not land. I went over to try a hand catch and the lower sensors caused to to go back up. I tried again while attempting to avoid the sensors with no luck. After that I tried landing again with with the sticks and this time it landed.
And that's why they call me "two fingers" ...As far as the hand catching with the sencers on I do it regularly , just get it from the side and slip my hand under
It quick and grasp it and don’t move till I have shut it down.
YesDid it do the hover at 5 ft even with the stick pulled down to override the landing caution???
