The AMA "guideline" is 400 feet within 3 miles of an airport... Not 400 feet within the entire United States.. read what you just posted..
Falcon... please reference in the above "Public Law" where it states a hobbyist is restricted to line of site, or 400 feet.. It's not in there.. the current guidance from the FAA, as it relates to hobbyists is a "recommendation".. go to the FAA website and look it up.. then look up the definition of "guidelines".. not to sound disagreeable but the difference between hobbyists
Operating rules and "for hire" rules are pretty stark.. it's a suggestion, and perhaps one with merit, but let's not call this something it isn't, which is a limitation.
Section 336c, it's the definition of a UAV under hobby use"
(c) MODEL AIRCRAFT DEFINED.—In this section, the term ‘‘model aircraft’’ means an unmanned aircraft that is— (1) capable of sustained flight in the atmosphere; H. R. 658—68 (2) flown within visual line of sight of the person operating the aircraft; and (3) flown for hobby or recreational purposes.
But this topic has been BEAT TO DEATH hundreds of times in the past. As I say, each and every time people come along and post it again as if it's not been discussed to death.
Then don't participate. Pretty simple.Section 336c, it's the definition of a UAV under hobby use"
Bottomline... I can't figure out why you reply. If this subject burdens you so why read and respond? Not once but twice! Fascinating. But I think I'm clearer on the guidelines. It sounds like there are no laws being broke if you fly beyond line of sight.
Best I can tell, the two here which are actual "statutes" directly designed for recreational model aircraft, are the LOS requirement, as they (FAA) clearly state in 336 that their interpretation allows for this, and the 5 mile notification requirement by congress, also stated in 336 and then codified in p.107.In reading the FAA material as closely as I'm able... It appears to me that most of the "regulations" are actually "recommendations" for hobbyists.. If you're flying for $$, then it's a whole different ballgame.. It says "we'd appreciate if you would.." not "you must"...
Safety Guidelines
- Fly at or below 400 feet
- Keep your UAS within sight
- Never fly near other aircraft, especially near airports
- Never fly over groups of people
- Never fly over stadiums or sports events
- Never fly near emergency response efforts such as fires
- Never fly under the influence
- Be aware of airspace requirements
Many of the others such as 400 ft. stem from AMA (CBO) guidelines (in certain situations under their guidance this can be exceeded) which congress stated you must operate under to be considered model aircraft. So if you do not comply, you are not model aircraft and are both operating illegally in the NAS, and endangering other aircraft in the NAS. So, they gotcha both ways.
It takes you out of the realm of hobby use. So if you are not legal under Part 107, you'd be in violation of the law.It sounds like there are no laws being broke if you fly beyond line of sight.
Discussing something to death doesn't mean it is settled.That is incorrect. There is no 400' law and the FAA has stated as much. You can operate above 400' and still fall under hobby use as a model aircraft. Again, discussed to death.
I also believe you are incorrect.
Straight out of the AMA Model Aircraft safety code:
(c) Not fly higher than approximately 400 feet above ground level...
So, please explain to us how you can violate an explicitly written code but still be operating within the CBO?
And if you are not operating under the CBO, you are operating illegally, unless you are p107.
This was a question before p107 codified 336, but is now law, IMO.
Good points, and it does appear to be a loophole.I mention it's been discussed to death as in those prior threads is all of the information.
The AMA liked to point out that the FAA called them a CBO because it support's building their membership. It means next to nothing.
I'm a CBO... you are a CBO.
This only means that local clubs, organizations, parties, etc. can set up rules that govern themselves. These are no laws and they only apply in limited situations. For example, lets say the AMA is going to have a racing drone competition. They can set rules for those that participate stating that they cannot fly faster then xx mph or fly higher then xxx'. Technically, this is regulating airspace, which only the FAA can do. The FAA allows CBO's to set these types of rules. It's not a law and it does not apply to non AMA members.
If you are not an AMA member you don't have to abide by _any_ AMA rules. Period. Think about it and it becomes obvious.... no one is required to know AMA rules (they are not laws/regulations). If I create a company, National UAV Fliers (NUF), it's a CBO. Do you now need to find out about me and abide by all of those rules? Same with the AMA.
No one is required to know about the AMA or follow their guidelines.
Yes and yes.Good points, and it does appear to be a loophole.
That said, I could still see them coming after you for "careless and reckless", if an incident occurred.
They would probably loose, based on your well made points, but your life would be miserable fighting them.
It's very interesting I was thinking about this point relating to CBO. I agree with you in that I could be a CBO you could be a CBO or anyone could be a CBO. It's a very loose definition of a regulating or regulatory type agency to be sure.I mention it's been discussed to death as in those prior threads is all of the information.
