Saying hi from Norfolk uk
Welcome to the forum! :)
Hi from Norfolk uk
I read your other posting and I know you have a Mavic Pro with some problems and I will let the "Pros" who know about this model help you...
However....................
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Happy Droning…
albestinspections
