Sharing the View
TAG
Has anyone come up with a way that someone could watch the live feed on another device while I'm flying. My wife would like to take in the view live. Thanks
If you fly with a mobile device that has an HDMI output (like the Nvidia Shield K1), you could use that to display the same view on another device that has an HDMI input.
I have a new mavic and I am trying to set it up. My Galaxy 5 ACTIVE and my Galaxy tab A 9.7 will not connect to the controller, although the controller connects to mavic fine. Will this Nvidia shield fit in the controller arms, looks kinda thick? Thanks!
Sent from my SAMSUNG-SM-G870A using MavicPilots mobile app
I've only seen one post here (this one) showing it fits. I tried to fit mine, but it was just too tight. I didn't want to scrape up my tablet by trying to slide it in.
It will fit using a set of 'Z' Clips, or someone got it to fit by removing the lower set of rubber gripper pads from the controller arms. I would go with the Z clips if you don't want to mod your controller, or if you still want to be able to use your phone at times. The K1 is a good way to get HDMI out to another monitor, many are using it.
F6Rider, thanks! I will look into the Z clips
Msinger, my thoughts exactly. By the way I got the Galaxy 5 ACTIVE connected, had to disconnect the upper cable first. I read that a couple of weeks and forgot about it by the time I got the Mavic. Lol [emoji12]
ryanhafeman
