Southern Delaware
RS Bush Pilot
Millsboro, DE, USA
Joined the forum last week, and I'm liking it, so I thought I'd check in here and say hello.
Can't really call myself a UAV or drone pilot; I've never flown one, or even saw one fly, other than YT videos. I bought an M3P a week or so ago, but it's still in the box.
I thought I'd like to do this, but after learning all about the new FAA RID access to anyone, now I'm just not so sure. Didn't plan to do anything more than fly for fun... no Y.T. videos or business ventures, just recreational.
I went ahead and got the TRUST certificate, downloaded B4UFLY, Airmap, UAV Forecast, and Part 107 study guide, even though my drone flights wouldn't come under 107.
I've been a licensed private pilot, fixed wing SEL, for many years, so going for the 107 shouldn't be too challenging.
Not sure if I'll keep the drone or not, but I'm already enjoying this forum, so I think I'll stick around, at least for a while.
Keep it, and enjoy it. RID, in my opinion, will not be an issue for your enjoyment. I think no more of it than having to have tags on my truck.
Welcome to the forum! :)
Welcome! If you are current as a pilot, you don't have to take the same exam since you should already be familiar with basic aerodynamics, weight and balance, and airspace. But if you're not current, it's just a lot cheaper to take the regular 107 exam.
I recommend getting the 107 license even if you're just flying recreationally. Recreational pilots are flying under an exception in the 107 regulations and can get into trouble pretty easily if they don't understand what "recreational" means to the FAA.
Onward and upwards!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Delaware, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Welcome to the forum from the beautiful woods of Maine!
Wotcher from the UK. If I'd known beforehand what a pain in the fundamental orifice the rules & regulations were going to become: I'd probably have thought it was too much like hard work for a hobby. But even though the R&R's are just getting more and more like those binding proper pilots, because I quickly became obsessed with aerial still photography, I'll carry on with my 'hobby', toe the regulatory line and put up with the restrictions... Because the end result is well worth the effort. Happy flying.
charliesunique
