Hi, I use Dji Go 4 with my MPP and need to slow down the stick movements.
How do I do this and what is the maximum I can reduce them by?
Adjust the EXP and GAIN settings in the DJI Go App. There are YouTube videos that give specific instructions and show examples of various settings/changes to these values.
I always lower my EXP from .25 to .20 for YAW (right/left) to slow down the jerky panning or panning too quickly. I do this for the Normal (P mode, NOT Sport Mode).
Note that all these values can/must be set separately for the P (photography) mode and the S (sport) mode.
Also, note that sometimes these values are reset to the default after some firmware upgrades, but not every time.
Many thanks - that was what I wantedIn DJI GO 4:
Hit 3 dots in top right corner
Top left corner (QUAD Icon) takes you to Main Controller Settings screen
Bottom option is Advanced Settings
in Advanced Settings, there is a separate section for EXP, Sensitivity, and Gain.
Notes:
1) You will have to have the drone powered on and connected to make and save changes here.
2) These instructions are using the latest IOS version of DJI GO 4 - Android may vary slightly
3) EXP and Sensitivity setting adjustments should get you the result you're looking for. You shouldn't have to mess with the GAIN setting, and I wouldn't mess with GAIN unless you know exactly what you're doing. There are some good YouTube videos that explain why better than I can.
Good Luck.
Please just continue in your first thread here Stick movementsHi, I use Dji Go 4 with my MPP and need to slow down the stick movements.
