Storing long term
Montypaks
So I want to store my Mavic for about 2weeks. Is it advisable to leave the batteries at 10 - 30%?
Tge controller is actually at 5%
Will the very low charge be detrimental or should I charge them all (including the controller) to 60% which is the typical storing percentage.
Before storing I always charge until the third led light just starts to flash ( ie just over 50%)
Reactions: Montypaks
Mavic batteries will auto-discharge to 50% after a set amount of time untouched - by default, this is 10 days (can be changed via app when attached to drone).
The timer resets any time you push the battery's button, however.
I don't know if the controller auto-discharges, but it should also be stored at about 50%.
Sorry to hijack the thread, but if the discharge “timer” is set to 10 days, I assume that flying, then leaving the batteries sitting a few days, then flying etc isn’t a problem...I don’t need to set it to discharge sooner. I don’t fly every day, especially during the winter here, but I will when it’s decent outside. If it’s more than 10 days the battery will discharge, and as long as I check it every couple of weeks to make sure it’s not too low, I should be ok?
Also, and I think I read this answer somewhere, topping off the battery before I fly is ok too? Like if I fly for a few minutes, put everything away for the afternoon, then top off the next day?
Thanks! Excellent info....
So guess I can just leave the batteries as they are then... (one solid light, one blinking light) which is around 25% - 37%
I'll charge the rc to 50%
Yes. That'll be fine for two weeks.
It's not a problem as long as you recharge the batteries before flying each time. It's not safe to fly with partially charged batteries.
Yes. Always fully charge your batteries before flying.
Reactions: Callum and Neebles
Perfect, thanks.
(Btw, I placed an order for some Strobon lights with you last night)
Sorry for crowding your thread @Montypaks
Thank you! I'll be sending out your package today.
FredFulf
