Can I switch between the 2? One flight litchi and the next DJI?
I have the Mavic 2 Zoom with the Smart Controller and do that all the time. Most of my flights are using go4 app, but I use Litchi when I want to fly a waypoint mission. I create the missions on my desktop computer using Litchi mission hub, and then retrieve and run them when needed on the smart controller using the Litchi app. Being that they are different flights I turn off the controller in between flights, but I'm sure you can just close one app and open the other if you want.Can I switch between the 2? One flight litchi and the next DJI?
Yeah bit of overkill and a not needed step, but whatever works for ya You can simply swipe down from top of the screen to bring up main menu....Select "Recent"...it will then show background apps running...then just select Go4/Litchi and swipe up to close any App, then it will return to main screen to open the other App. Give it a try, sounds like alot but in reality it is 5 seconds to do when you learn the procedure....but to each their own.Being that they are different flights I turn off the controller in between flights, but I'm sure you can just close one app and open the other if you want.
A word of caution. Keep in mind that with Litchi you can set some parameters for the AC like turning the bottom sensors OFF that may stay off when you go into DJI FLY where there is no option for the bottom sensors. I found that out with my Mini and had only GPS positioning and no precision ground location accuracy. Had to exit FLY and go to Litchi to turn sensors back on then it worked fine with FLY. Not sure what other parameters might not auto reset.Can I switch between the 2? One flight litchi and the next DJI?
