Telephoto, how to set Raw?
kanesimages
Denver
I’ve updated my Mavic 3 and am having trouble locating any way to use the x7 telephoto in Raw. The most obvious would be to touch the JPEG symbol on the home screen thinking it would give me a pop up to slide to Raw. But that doesn’t give me the option for raw…just jpeg. What am I missing?
Any help appreciated.
A couple of quick ideas:
Are you sure you have the latest firmware? v01.00.0700,? Did you go through a power off/power on cycle after updating the firmware?
Found this, see if it helps you
Here's how:
Select the 7x camera
Click where you see JPEG, down in the lower right
Select Raw or J+R
Could you post two screenshots like @Meta4 did above in #4 so that we may see what you see when you do as he instructed?
I finally got it to work. I did a second firmware refresh, to my app, the drone and to the remote. Im relieved. Thanks for trying to assist.
Reactions: PAW
tansh
