Did you use any LUTS or all old fashion CC? Either way, you did a great job!Thanks. Just the good old M3. Shots taken with both cameras, stating obvious
Starting with LUT for the 24mm then grading. Since the 162mm only shoots in Normal mode I did the good old fashion grading in Davinci Resolve trying to match the mood of the 24mmDid you use any LUTS or all old fashion CC? Either way, you did a great job!
Thank You for the replyStarting with LUT for the 24mm then grading. Since the 162mm only shoots in Normal mode I did the good old fashion grading in Davinci Resolve trying to match the mood of the 24mm
Very cool, I like it!
I see DR continues to perform black magic.
ThanksVery well done. Thank you for sharing!
