- Joined
- Oct 12, 2016
- Messages
- 28,355
- Reactions
- 31,225
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
Thanks for clarifying. They looked similar in the one video I saw.The connectors are not the same.
Thanks for confirming that I wasn't hallucinating when I saw the similarity in one of the videos. DJI should have thoughtfully sent my Mavic early, to avoid my passing along speculative misinformation! The power requirements are different, so even though the P4 100W charger can be used with a new Mavic 100W hub, I suspect the connectors need to be incompatible to prevent confusion and possible battery damage or even fires!Yes, they look very similar up close too.
Can you share an example of that please?other thing i found, the camera makes red dots on raw pictures which a high contrast difference (ex sunset). dji cleaner program helps, but im bothered its still a problem (this also exists on the P4)
How about:-
- the controller battery is quite small and you'll be charging it more often
Mine went down to 60% after two flights whereas the P3 controller seems to go on forever. I literally cannot remember the last time I charged that thing.
I've been charging both at the same time, never really heard of that and both battery and RC both charge fairly fast!??Yes and I cannot find mention of it in the manual but I am pretty sure with the P3 charger the manual said not to charge both controller and a flight battery at the same time. If that is the same for the Mavic so you might be waiting for hours.
