Trepidation
Sound22Card
Langley, B.C., CANADA
Greetings,
I received one of these little varmints (E58) and haven't yet fired it up. I'm still reading and looking at vids.
I'm too close to an airport AND heliport to try it out in our convenient open park behind us. ****!
I truly want to master flying this guy, as I've had a desire for something that flies like this, since I was a kid.
~ray
Hello from the Crossroads of America Sound22Card.
If you have success with this drone, upgrade to a DJI mini 2 or something better in the DJI line up.
Good luck and welcome to the Forum. :cool:
Greetings,
~ray
I'm sure you could set it up and test it in your yard at low altitude and distance. Just to make sure it works. How close are you to this airport? My wife bought my brother in law a similar drone for my brother and law, and even though I helped him he still hasn't done anything with it. Total loser!
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Since you are flying an Eachine E58, you might want to also consider joining our sister Site,
There is a small Sub-Forum on for your specific Drone, but you are welcome here…
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Sound advice!
It weighs over 250g, so that's not legal in Canada. Not only do you need a sRPAS certtificate to fly it at all, but flying within controlled airspace (which Langley is mostly covered by) requires a Special Flight Operations Certificate.
More information on the legalities here:
And an interactive map showing where you can (and can't) fly):
Photogeezer
